    It's also in the worst vertical position because it's having to lift the whole gantry vertical not horizontal.
    What if you put 2 wire ropes from the gantry over pulleys at the top attached to a counter weight at the back, I'm sure you must have considered this.
    No I haven't considered it really has it's not a problem and it works fine. Thats was the point in mentioning it because if it works ok in this orientation then it will work fine in the other and to be honest for this size machine it's non starter to have gantry run Vertical.!
    Agree thou if space was limited and it had to be vertical then it would make sense to design a counter balance into the design from the start just to help the motor out a bit.
  1. Things to do differently next time....
    By mocha in forum General Discussion
    Last Post: 15-04-2012, 09:12 PM
  2. a few things cut with my router
    By jonm in forum Woodworking Project Showcase
    Last Post: 02-10-2010, 09:54 AM
  3. BUILD LOG: Planning and build of my "8020" aluminium CNC Router
    By monza in forum DIY Router Build Logs
    Last Post: 06-02-2010, 11:55 PM
