  1. #3
    Quote Originally Posted by brumster View Post
    Was thinking linuxCNC at first, in terms of controller board I've yet to look into anything. Something USB-based would be good rather than parallel port.
    Welcome to the forum Dan, I for one have gained a lot of useful knowledge from the kind people on here.
    Re Linuxcnc I don't think you can use the USB port with it but you can use more than one P.P. or purchase a mesa card to fit into the pc that will enable you to use lots of input and output pins.
    Also Linux use the real-time kernel so does not need to buffer its gcode output.
    There is quite a lot of debate on Mach3 verses Linux but they are both good as far as I can tell.
    Good luck and don't purchase anything until you check on here with your design etc. ..Clive
  2. The Following User Says Thank You to Clive S For This Useful Post:
  1. a 4th axis... and quick
    By kingcreaky in forum Marketplace Discussion
    Last Post: 29-10-2013, 11:34 AM
  2. Need a quick hand with some resitors please
    By Fivetide in forum General Electronics
    Last Post: 07-04-2013, 08:58 PM
  3. quick reply box
    By wilfy in forum General Discussion
    Last Post: 01-03-2013, 11:10 AM
  4. Quick Advice Needed - F&S
    By Tenson in forum Tool & Tooling Technology
    Last Post: 01-01-2013, 06:38 PM
  5. Quick question
    By m.marino in forum General Discussion
    Last Post: 18-02-2011, 04:30 PM
