Thread: 2.2kw spindle Heating Up
As i am not an expert, and my English are not very good i will suggest you check
1. The bearings
2. Try to blow or suck from the inlet or outlet tube of the cooling system. If no air can pass through try to clean it because that means that even the air cant pass trough the cooling system in order to spread heat of the spindle to the environment
3. One basic question (because you don’t mention it) is if you use the spindle to cut something or you just turn it on with no cutting load. If you use it to cut any material check the bit condition
4. If you use a VFD (inverter) in order to control spindle speed, try to check it. May be bad electrical parameters cause overheating
I can think of something else
Vagelis
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
CNC Spindle Repair and Spindle Replacement for any Machine of any Manufacturer
By spindeldoctor in forum Manufacturer NewsReplies: 0Last Post: 13-11-2013, 07:50 PM -
Spindle lock mechanism for 2.2kW china spindle
By Jonathan in forum Generic Chinese SpindlesReplies: 8Last Post: 13-08-2012, 08:39 PM -
WANTED: Spindle holder for 1.5kw Chinese spindle.
By jcb121 in forum Items WantedReplies: 19Last Post: 14-10-2011, 02:07 PM -
DIY Spindle - What type of bearings are best suited for a spindle.
By 8iggles in forum Spindles & Drive MotorsReplies: 18Last Post: 09-02-2011, 10:15 PM
