The pieces are cut as two 'identical' interlocking spirals, so the gap is due to the tool width. The wood is 8mm thick so I had to use a tool with a long flute, and 2.2 was the smallest I had. The planks were 6" so the end size is 140x130 mm. The dxf was done with corel draw and is a bit steppy. and I had to do a lot of editing on the Gcode to get rid of redundant cuts. They are intended to be separate pieces to make two trivets if necessary. They were finished with a rub of sandpaper and teak oil.
The Gantry router was Made in Devon, so there were a number of runs that ended up as kindling.
If anyone wants the Gcode I'll post it.
Cheers,
Rob
23-12-2013 #2
Rob: Very nice and different I think that the gaps add to the design
It would be nice to see the gcode or the dxf or even both. ..Clive
Optimum air pressure for the laser air assist?
By Want2build1 in forum Laser Machines & BuildingReplies: 0Last Post: 13-05-2014, 09:50 AM -
Bottle jack with pressure guage port in the UK?
By Inquisitor in forum Marketplace DiscussionReplies: 12Last Post: 31-12-2012, 06:50 PM -
Well, it had to happen
By Smiler in forum General ElectronicsReplies: 3Last Post: 24-03-2009, 04:39 AM
