Hi Simon,
To be honest, I haven't got the patience to check through your diagram, but I presume you have built it in parts and tested it. I used a 2nd BoB (5v) to do the limit switches as the LJ12A's don't work below 9 or 10v. and I wanted more inputs. I have modified all my proximity switches to work in pass-by as I got a bit fed up with crushing them. It doesn't need much force to push the end in and kill the device. Also be aware that you need a switch to deactivate the limit sensing, so you can reset MACH3 (if you use it), otherwise you can't jog off the limit switch.
Cheers, Rob
I retired in 1999 (health issues) so all I do nowadays is play CNC and electronics.
EMC2 home/limit switches... only acting as limit?
By vputz in forum LinuxCNC (EMC)Replies: 4Last Post: 15-10-2014, 09:51 AM -
Limit and Home Switch Choice
By Wobblycogs in forum General ElectronicsReplies: 25Last Post: 02-12-2013, 06:16 PM -
FOR SALE: Z axis with Home/limit switch and Nema 23 3nm
By Shinobiwan in forum Items For SaleReplies: 6Last Post: 02-02-2013, 10:54 AM -
Limit switch wiring question ...
By Wobblybootie in forum General ElectronicsReplies: 20Last Post: 31-10-2010, 11:06 AM -
Limit switch's - best configuration?
By HiltonSteve in forum General ElectronicsReplies: 16Last Post: 13-08-2009, 01:26 PM
