Thread: Spindle motor rewind
12-04-2014 #20
Rewinding a motor will only increase its torque rating if you manage to fit more copper in the stator slots than the original. Changing the number of turns in series/parallel (etc) primarily changes the voltage rating - it is the *total* current through the slot that matter when calculating the torque output. The total current you can put through the slot depends on how much copper you can fit - too much current or too little copper = more heat.
If you just copied the existing winding, but increased the number of turns by the ratio of the new to old voltage rating, then it would be OK. We can go into a lot more detail if you want to, but it's hard to say how much there is to gain from this without actually seeing the motor inside.
That is well within the rating of the VFD I have designed/made.
AC servo motor to replace a 3 phase induction motor on a mill spindle.
By rnr107 in forum Spindles & Drive MotorsReplies: 2Last Post: 23-04-2014, 03:14 PM -
WANTED: Router Spindle Motor
By swinds in forum Items WantedReplies: 3Last Post: 26-04-2012, 10:43 AM -
Spindle Motor
By pdl in forum Stepper & Servo MotorsReplies: 0Last Post: 09-08-2011, 10:56 AM -
Spindle motor problems
By geoffby in forum Motor Drivers & ControllersReplies: 11Last Post: 07-11-2010, 08:25 PM -
servo motor as spindle motor
By Scott in forum General DiscussionReplies: 1Last Post: 03-10-2010, 06:42 PM
