26-12-2013 #2I found this was a problem only after I bought the gear, it seems the ABB ACS355 can not control my ELTE spindle (2.2kw 24000 rpm 400hz) in vector mode. I use the same inverter on another machine that has a standard 2.2kw induction motor and it works in vector mode for that without problem. You therefore need to read the manual for the VFD to see if it can handle your spindle.Does it make sens to buy vector controlled VFD for 350$ instead of u/f controlled for 250$?
NEW MEMBER: new member building a cnc router
By steeplejack in forum New Member IntroductionsReplies: 1Last Post: 11-10-2017, 05:07 AM -
Help on building an enclosure
By thomashomer1986 in forum General ElectronicsReplies: 12Last Post: 02-02-2014, 06:38 PM -
NEW MEMBER: CNC and other Machine Building Berlin
By Andikid in forum New Member IntroductionsReplies: 1Last Post: 07-10-2010, 11:30 PM -
NEW MEMBER: Started building!
By bobgrant in forum New Member IntroductionsReplies: 1Last Post: 02-09-2010, 09:42 AM -
BUILD LOG: Building a mechmate here in the u.k
By kingfisher in forum DIY Router Build LogsReplies: 1Last Post: 30-01-2010, 02:13 AM
