When I try to run the spindle in vector mode it immediately puts the VFD into fault, the fault code (which I can't remember for certain) says something about various parameters having to meet certain conditions, which clearly they do not at the moment. I did not follow up on this and unfortunately I am not in a position to try the spindle just now. Because it worked fine in v/f mode I decided to leave further investigation till later.
With my other machine that does work in vector mode I found quite a difference but that's only because I tried it in both modes so could see the difference first hand. It does seem to be more responsive to varying load such that it does not slow down when load is applied in vector mode, also because I use it at very low speed for bobbin sanding it works much better in vector mode.
NEW MEMBER: new member building a cnc router
By steeplejack in forum New Member IntroductionsReplies: 1Last Post: 11-10-2017, 05:07 AM -
Help on building an enclosure
By thomashomer1986 in forum General ElectronicsReplies: 12Last Post: 02-02-2014, 06:38 PM -
NEW MEMBER: CNC and other Machine Building Berlin
By Andikid in forum New Member IntroductionsReplies: 1Last Post: 07-10-2010, 11:30 PM -
NEW MEMBER: Started building!
By bobgrant in forum New Member IntroductionsReplies: 1Last Post: 02-09-2010, 09:42 AM -
BUILD LOG: Building a mechmate here in the u.k
By kingfisher in forum DIY Router Build LogsReplies: 1Last Post: 30-01-2010, 02:13 AM
