    I managed to get it all connected up again today, the drive trips on fault F1009 when I switch to vector mode, remember it works great in v/f mode.
    Check parameter settings. Following
    must apply for induction motor:
    • 1 < (60 · 9907 MOTOR NOM FREQ / 9908 MOTOR NOM SPEED) < 16
    • 0.8 < 9908 MOTOR NOM SPEED / (120 · 9907 MOTOR NOM FREQ / Motor poles) < 0.992
    So point 1.
    motor freq = 400
    motor speed=24000
    60 x 400 / 24000 = 1
    well it says it should be greater than 1 and less than 16
    point 2.
    motor poles = 2
    24000 / ((120 x 400)/num poles)) = 1
    it says it should be greater than 0.8 and less than 0.992 so that's why it's going into fault.
    I changed the nominal speed to 23760 and that solved the problem.
    Now though it trips on over-current but I'd had enough today, and yes I do have the correct figures in for nominal current it's 9.5 Amps and max current is set to 17.6 Amps
  1. NEW MEMBER: new member building a cnc router
  2. Help on building an enclosure
    By thomashomer1986 in forum General Electronics
    Last Post: 02-02-2014, 06:38 PM
  3. NEW MEMBER: CNC and other Machine Building Berlin
    By Andikid in forum New Member Introductions
    Last Post: 07-10-2010, 11:30 PM
  4. NEW MEMBER: Started building!
    By bobgrant in forum New Member Introductions
    Last Post: 02-09-2010, 09:42 AM
  5. BUILD LOG: Building a mechmate here in the u.k
    By kingfisher in forum DIY Router Build Logs
    Last Post: 30-01-2010, 02:13 AM
