	29-12-2013 #7
Maybe not want you want to hear but it's all good straight advice that's been learnt the hard way by me and others. I'm often contacted by silent watchers who have jumped straight in and not done the prep or homework only to fall foul buying wrong parts or choosing a weak trouble some design. . . . . If you continue and don't put in the ground work then I guarantee you you'll fall foul and be contacting some one within time.!!
Doesn't matter if you buy a Kit or build DIY your going to have to deal with getting the Rails parallel and on the same Plane. If your not prepared to do this then I suggest you just buy a Machine ready built because there are no kits that will bolt together(or weld) and ensure the rails are parallel and on same Plane.
Aligning and getting rails aligned etc isn't difficult has it first appears and there are a few tricks which can be employed like having an adjustable top rail which gets shimmed or using epoxy resin. Because your only cutting wood then the tolerances are relatively low so it's quite easy and quick to get rails close enough just using shims.
Now regards the CNC router parts machine then yes they work but they have there issues which don't get mentioned so much, like the rails clogging bearings and sticking Etc.!! . . . I certainly wouldn't call it commercial spec and not even Heavy duty DIY.! . . . . A much better machine with far more robust components can be built for less money.
Regards Components then be careful when reading sites like Cnc cookbook because they are quite heavily Mill orientated and while routers use the same Kind of components the sizes and speeds they run at are much higher so are very different specs. Then you have other things to consider like best Linear motion for the Job, IE Ballscrews or Rack & pinion which again are very different spec to mills and critical to good performing machines.
It's actually here where new users most commonly fall foul and buy the wrong parts for the job which leads to at best an under performing machine or worst one not fit for purpose. Next is weak design and trying to cut corners.!!
So IMO given your Brief of Commercial duty and Low Budget then your only option is to self build but PLEASE PLEASE LISTEN and do the home work on the forum because if not then you'll waste valuable time and Money.!
Good luck.Last edited by JAZZCNC; 29-12-2013 at 07:22 PM.
Ancient CNC machine- advice needed!
By tom_65a in forum Machine DiscussionReplies: 6Last Post: 11-05-2014, 11:17 AM -
Flappy machine - Advise needed please!
By cncJim in forum Machine DiscussionReplies: 22Last Post: 01-11-2013, 03:23 PM -
Free Machine Plans
By CRP in forum Machine Frames & BedsReplies: 0Last Post: 24-07-2013, 06:32 PM -
BUILD LOG: Wood router machine, 600x400
By troyboy1 in forum DIY Router Build LogsReplies: 2Last Post: 05-12-2012, 12:47 AM -
RFQ: help needed to make cnc machine maybe 2-3 and will pay
By scnc in forum Projects, Jobs & RequestsReplies: 10Last Post: 22-11-2012, 12:31 AM
