Page 4 of 6 FirstFirst ... 23456 LastLast
  1. #31
    Bear in mind that ABB's recommendations for cable size are probably trying to cover themselves for most applications, whereas our application is quite specific.
    Jonathan, I fully understand what you are saying but it's a bit like the DIY person who installs a new 13amp socket outlet using a bit of 3 core flex because he only wants to plug a table lamp into it. They sell the house and next owner plugs a 3 bar electric fire into it.
    Last edited by EddyCurrent; 10-01-2014 at 08:34 PM. Reason: I meant 'to' not 'too'
  2. #32
    Lives in Marple Stockport, United Kingdom. Last Activity: 19 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,347. Received thanks 620 times, giving thanks to others 89 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    The supply cable could be 4 core armoured.
    Eddy Do you not think that this is a bit OTT as on these type of VFD's there is not the provision to connect wire armoured cable with a separate box. I don't know of anybody in a DIY situation that would use it. Just my two cents worth ..Clive
  3. #33
    This is going to sound rich coming from ME but come on Lads don't turn it into an argument and pyshics lesson so to confuse the Man.
    Bush Flyer 1.0mm/2 is fine for these Spindles and what I've fitted many times without any issues even on heavy use machines but if you want to cross I's & Dot the T's then use 1.5mm/2.
    2.5mm/2 for the VFD Input. If near heavy traffic or chance of damage etc then armoured if not then just use 2.5 Flex not ridged mains cable.
  4. #34
    Right 1.5mm/2 cable for the spindle and normal 3 core for the mains but the size I was going to buy 1.5mm/2 cable as that can handle 15amps, and a wall plug is only 13amps.
    2.5mm/2 would be able to handle 20amps but still the wall plug is only rated at 13 amps.
    Or have I got to take the main feed straight from the fuse box to get 45amp supply in the house ( I hope not.)
  5. #35
    2.5mm^2 for the VFD input is excessive. 1mm^2 is adequate...so if you want peace of mind go for 1.5mm^2!
    It's a 1.5kW spindle, so anything above that and the VFD will cut out within a few seconds - i.e. too fast for the cable to heat up, so you only need to rate the cable for 1.5kW. 1500/230=6.5 amps, hence 1mm^2 (rated for 10 amps) is plenty for a 1.5kW spindle and just enough for 2.2kW as 2200/230=9.6A.
  6. #36
    Didn't realise it was 1.5Kw spindle so yep 1.5^2 fine.
  7. #37
    It's recommended that the supply cable also has a screen so I was meaning the supply cable to the control panel enclosure which I assumed would be metal and wall mounted. Just because people keep saying it's DIY I'm not into dumbing things down. I would suggest the supply be fed by a 16 amp minimum supply, if you want a plug and socket then it's the blue type.
  8. #38
    Right that's it sorted, I have ordered 4 core 1.5mm/2 screened and 1.5mm/2 normal 3 core mains.
    Thanks for all your help, once I have it set up and I run into problems I will probably need your help again.
  9. #39
    From your post #25
    The VFD is 1.5kw HUANYANG VARIABLE FREQUENCY DRIVE.
    The motor is a, Germany Imported Bearing, water cooled spindle 0.8Kw
    I take it your spindle is 0.8Kw .. Clive
  10. #40
    From your post #24
    Ahh, this is the point where you consider Eddy's post #31:
    Jonathan, I fully understand what you are saying but it's a bit like the DIY person who installs a new 13amp socket outlet using a bit of 3 core flex because he only wants too plug a table lamp into it. They sell the house and next owner plugs a 3 bar electric fire into it.
    We wouldn't want someone to change the 800W spindle to 1.5kW and potentially melt the 0.75mm^2 wire that would be fine for the former...
  1. Chinese 6040 CNC Router Advise Needed
    By Bob Hepple in forum Chinese Machines
    Last Post: 27-11-2013, 12:00 PM
  2. Has my air compressor died?
    By Jonathan in forum General Discussion
    Last Post: 15-10-2012, 12:08 AM
  3. I need advise again
    By habibuzziwa in forum General Discussion
    Last Post: 08-10-2012, 10:08 AM
  4. I need advise
    Last Post: 03-10-2012, 10:50 AM
  5. Advise on buying a new CNC router.
    By brlaw in forum General Discussion
    Last Post: 09-07-2011, 05:00 AM
