2.5mm^2 for the VFD input is excessive. 1mm^2 is adequate...so if you want peace of mind go for 1.5mm^2!
It's a 1.5kW spindle, so anything above that and the VFD will cut out within a few seconds - i.e. too fast for the cable to heat up, so you only need to rate the cable for 1.5kW. 1500/230=6.5 amps, hence 1mm^2 (rated for 10 amps) is plenty for a 1.5kW spindle and just enough for 2.2kW as 2200/230=9.6A.Last edited by Jonathan; 10-01-2014 at 06:20 PM.
10-01-2014 #2
Chinese 6040 CNC Router Advise Needed
By Bob Hepple in forum Chinese MachinesReplies: 24Last Post: 27-11-2013, 12:00 PM -
Has my air compressor died?
By Jonathan in forum General DiscussionReplies: 9Last Post: 15-10-2012, 12:08 AM -
I need advise again
By habibuzziwa in forum General DiscussionReplies: 14Last Post: 08-10-2012, 10:08 AM -
I need advise
By habibuzziwa in forum General DiscussionReplies: 7Last Post: 03-10-2012, 10:50 AM -
Advise on buying a new CNC router.
By brlaw in forum General DiscussionReplies: 2Last Post: 09-07-2011, 05:00 AM
