    Right that's it sorted, I have ordered 4 core 1.5mm/2 screened and 1.5mm/2 normal 3 core mains.
    Thanks for all your help, once I have it set up and I run into problems I will probably need your help again.
    Lives in Marple Stockport, United Kingdom. Last Activity: 16 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,347. Received thanks 620 times, giving thanks to others 89 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    From your post #25
    The VFD is 1.5kw HUANYANG VARIABLE FREQUENCY DRIVE.
    The motor is a, Germany Imported Bearing, water cooled spindle 0.8Kw
    I take it your spindle is 0.8Kw .. Clive
    From your post #24
    Ahh, this is the point where you consider Eddy's post #31:
    Jonathan, I fully understand what you are saying but it's a bit like the DIY person who installs a new 13amp socket outlet using a bit of 3 core flex because he only wants too plug a table lamp into it. They sell the house and next owner plugs a 3 bar electric fire into it.
    We wouldn't want someone to change the 800W spindle to 1.5kW and potentially melt the 0.75mm^2 wire that would be fine for the former...
  1. Chinese 6040 CNC Router Advise Needed
    By Bob Hepple in forum Chinese Machines
    Last Post: 27-11-2013, 12:00 PM
  2. Has my air compressor died?
    By Jonathan in forum General Discussion
    Last Post: 15-10-2012, 12:08 AM
  3. I need advise again
    By habibuzziwa in forum General Discussion
    Last Post: 08-10-2012, 10:08 AM
  4. I need advise
    Last Post: 03-10-2012, 10:50 AM
  5. Advise on buying a new CNC router.
    By brlaw in forum General Discussion
    Last Post: 09-07-2011, 05:00 AM
