Post a pic of the centec. Ive got one with a fine feed vertical head as well. I believe that three different types of head were made but I cant be sure about that.
I hope this works!
You can see the fine feed and the two bolts on sliders so the worm pivots away allowing use of the rapid feed lever. You can also see the bent knob on the gear range selector and the small chunk out of the bed.
The quill is MT2 and is threaded, the collets go straight into the taper and don't need a drawbar as the nut holds them up into the taper. I only figured that out today haha.
