    So I've been planning to build this thing for quite some time now, finally I have taken the plunge and started to finalise the specs. I have read, re-read and read again many of the posts on here looking for advice and ideas, and I am now ready to lay out my designs in front of you guys for some no doubt frank but highly constructive criticism hehe!
    My machine will be used for every type of material between balsa (model making) and Aluminium, and must be able to cut 1220mm x 2440mm sheets of the above materials at times. I will type out my specs a little later on as I'm limited on time at the moment, but I have put together the design in Sketchup for the general idea, and wondered before I go any further if you can give me ideas as to whether it will be strong enough or not?
Name:	CNC CROUTER - Frame Expanded.jpg
ID:	11089Click image for larger version.
Name:	CNC CROUTER - Frame.jpg
ID:	11090Click image for larger version.
Name:	CNC CROUTER.jpg
    Last edited by Wejjmeister; 05-01-2014 at 06:39 PM. Reason: Change title to be more specific!
  1. BUILD LOG: First steel diy CNC router build
  2. A Sturdy Steel Framed Machine Design
    By Boyan Silyavski in forum Machine Frames & Beds
    Last Post: 06-11-2013, 05:58 PM
  3. BUILD LOG: Steel Framed CNC router
    By Joe in forum DIY Router Build Logs
    Last Post: 23-06-2013, 10:45 PM
  4. BUILD LOG: Steel Framed Router
    Last Post: 14-09-2011, 06:51 PM
  5. BUILD LOG: My steel framed router
    By pavlo in forum DIY Router Build Logs
    Last Post: 06-03-2011, 10:08 PM
