  1. #10
    Quote Originally Posted by Wejjmeister View Post
    Any other glaringly obvious mistakes in the design??
    Not glaring but you have gone too far with removing the diagnols but not far enough in other places.?
    I would have diagnols at each end of the sides. But would remove the central upright and re-space others on all the Bed support frames.
    Would also have a Bed support frame on each side upright and not laid flat in like you have in centre.
    The rest looks ok.
    EDIT: I would also on the outer End bed supports have diagnols on inside lower beam which fastens to the sides to help hold frame square while setting up and bed frame is fastened. Like this but larger and to suit your design.
ID:	11243Click image for larger version.
  1. BUILD LOG: First steel diy CNC router build
  2. A Sturdy Steel Framed Machine Design
    By Boyan Silyavski in forum Machine Frames & Beds
    Last Post: 06-11-2013, 05:58 PM
  3. BUILD LOG: Steel Framed CNC router
    By Joe in forum DIY Router Build Logs
    Last Post: 23-06-2013, 10:45 PM
  4. BUILD LOG: Steel Framed Router
    Last Post: 14-09-2011, 06:51 PM
  5. BUILD LOG: My steel framed router
    By pavlo in forum DIY Router Build Logs
    Last Post: 06-03-2011, 10:08 PM
