09-01-2014 #2
They wont shrink or sink but they do not harden to the same levels as paints are meant to be somewhat flexible to resist cracking etc, so it wouldn't be suitable for this particular job as it would 'give' unlike the epoxy resins used in these forums before which cure fully.
09-01-2014 #3
10-01-2014 #4
Next round guys Mk3!
Removed steel form sides and changed bed supports. Any better? Saves a lot of excess steel.
Started on ideas for rails etc... let me know your thoughts please.
Think this should provide a strong setup, also thinking about using BK blocks to mount Ball screws? Will these be suitable?
Thanks!!
10-01-2014 #5
The covers round your ballscrews will fill up with swarf and cause the ballnut to fail prematurely.
Best way is to use a rotating nut. If not, then at this length you'll want two angular contact bearings at both ends to get a respectable speed. Search on Google 'ballscrew critical speed' for more information.Last edited by Jonathan; 10-01-2014 at 03:14 PM.
A Sturdy Steel Framed Machine Design
By Boyan Silyavski in forum Machine Frames & BedsReplies: 0Last Post: 06-11-2013, 05:58 PM -
BUILD LOG: Steel Framed CNC router
By Joe in forum DIY Router Build LogsReplies: 14Last Post: 23-06-2013, 10:45 PM -
BUILD LOG: Steel Framed Router
By GTJim in forum DIY Router Build LogsReplies: 52Last Post: 14-09-2011, 06:51 PM -
BUILD LOG: My steel framed router
By pavlo in forum DIY Router Build LogsReplies: 17Last Post: 06-03-2011, 10:08 PM
