    dsc's Avatar
    Lives in Lincoln, United Kingdom. Last Activity: 17-06-2020 Has been a member for 9-10 years. Has a total post count of 252. Received thanks 1 times, giving thanks to others 11 times.
    Curious what people use on aluminium to hold DTIs? I'm trying to measure a few things with a DTI on a machine which is made from aluminium / 316 stainless and of course mag bases don't stick to anything. I've tried clamping the base, but access is very tricky and measurements are not reliable. What the normal approach to such a problem?
    Thanks in advance for any help.
    Regards,
    dsc.
  2. Vacuum clamp, like the base on this vice, but only works on smooth surfaces.
    Edit: look here VACUUM CLAMP BASE ONLY
    expensive tho...
    I clamp a dial guage to a surface guage column and hold the base down firmly to take measurements, for awkward situations I've used a variety of woodwork clamps, ratchet straps and spare stock to hold bases down - if none of this is possible discrete tapped holes are a consideration,
    - Nick
    dsc's Avatar
    Vacuum clamps - looks neat, but a bit costly. I guess I just need a few more clamps of different sizes, a few DTI holders and keep doing what I was trying before. I do often use a V-block, clamped to the surface, with a round rod clamped in the V and a DTI on the end. Not very flexible, but a full blown, even miniature mag base cannot be clamped / won't fit in the tight spaces due to the length of the rods.
    Regards,
    dsc.
    Uses compressed air, also shows use for cnc work
    V-Clamp, Vacuum clamps powered by compressed air.
    dsc's Avatar
    If only I had a source of compressed air Eddy:)
    Regards,
    dsc.
    magma1974's Avatar
    Location unknown. magma1974 Last Activity: Has a total post count of n/a. Referred 6787 members to the community.
    I stick magnetic base to spindle and use for mesurement on aluminium part
  1. Rotary broach tool holders and tooling
    By dazza in forum Tool & Tooling Technology
    Last Post: 06-12-2014, 01:06 AM
  2. FOR SALE: New NT-APU Drill Chuck Holders are for sale!
    By jille in forum Items For Sale
    Last Post: 13-03-2012, 08:52 AM
  3. BT 35 tooling and DA holders
    Last Post: 19-07-2011, 03:22 PM
  4. WANTED: Tool holders for T2 (I think) quick change toolpost
    By Jonathan in forum Items Wanted
    Last Post: 07-05-2011, 10:30 AM
  5. Test cutting materials
    Last Post: 05-12-2010, 10:27 AM
