Im so sorry im rising such old topic from the ashes, but it is the only one on the internet with same problem as mine. I recieved my machine and it could only go to about 500 RPMS less than specified. I was sent by manufaturer adjustment procedure and while trying it the motor has jumped 5800 RPM and fuses exploded. My PCB is a newer variant with IKCS22F60F2C . It could be seen PCB was hand repaired before as many other junk Chinese packed on this machine (i was an one time buyer, so great way to get rid of various defective parts that were not shipped to Optimum). I replaced the burnt PFC stage, IKCS22F60F2C, input rectifier and my board works now. However the motor does not work and PCB only makes short 6 flashes (error code maybe?) and freezes. I managed to get a new tested board, but this behave same as one i repaired.
Im suspecting the motor, but never worked with BLDC motors in past. How should i test this motor? Its same as motor allready shown here. Should i open it up and test Hall sensors?
25-11-2014 #2
25-11-2014 #3
2 months of trouble, but started working tonight. So i removed the motor, powered the hall board with a bench power supply and tested the output of them, all of them worked ok. I measued ressitance to ground and between terminals, it was ok. I tried insulation tester and all windings seemed to be ok. I tried applying DC to terminals and all of them slightly moved the motor.
I reinstalled the motor again and same thing happened. While starting the motor ON/OFF switch gave 6 flashes and went silent. As i was speaking some rude words to it i pressed the on button few times in series and motor started. Now it works ok. I tried for research purpose to disconnect motor terminals and it again gave 6 flashes and go out. After pressing on button 3 times in row, the PCB "resets" and it works nicely afterwards.
I guess the PCB goes to somekind of protection mode after the motor has been disconnected, and 3 pushes of the ON button reset it. Even the manufacturer does not know this (or does not want to tell).
Im attaching a picture for this PCB as future reference if someone will google this situation in future. Furthermore i will give discovered procedure for adjusting speed range. Pressing the lower button on small PCB you adjust the maximal speed with speed pot, and pressing the upper button you adjust the minimall allowed speed.
The Following User Says Thank You to hacklordsniper For This Useful Post:
26-11-2014 #4
Holly sh.t !!! i discarded the whole crazy system because of lack of information about this reset procedure…. thanks to "manufacturer" who doesn't KNOW or even worse doesn't TELL ( it is not written in the documentation provided ) and who probably "prefers" to sell control boards ( +1000e ex vat ) AND motors ( +1000e ex vat )
So PM for spare parts to bargain ( 1 motors plus 2 boards )
26-11-2014 #5
26-11-2014 #6
Sorry, i havn't this option
26-11-2014 #7
Thank you, i guess the board is not very compatible with my machine. It can also be seen there is much changes on my version of board.
Does not matter, i would anyway buy this boards for study and repair. I would not buy motor tough, so if you want to sell me this PCB-s, please write to my PM
Can anyone identify this control board and help use it
By SimonMaltby in forum Chinese MachinesReplies: 4Last Post: 28-12-2017, 01:35 PM -
eBay: Emco vmc 100 milling machine and control unit plus manuals
By Lee Roberts in forum Items On eBay UKReplies: 0Last Post: 15-06-2017, 05:16 PM -
FOR SALE: £500 Vertical milling machine on stand, ready for steppers and control system
By petemono in forum Items For SaleReplies: 0Last Post: 06-02-2014, 09:52 PM -
eBay: Denford Novamill SmartStep Control Board + Spindle Board
By danielbriggs in forum Items On eBay UKReplies: 0Last Post: 30-05-2013, 06:52 AM -
Help! Stepper control board
By Ross77 in forum General ElectronicsReplies: 10Last Post: 28-05-2009, 01:42 AM
