    Happy New Year !
    See the circuit board mounted on the end of the motor, make sure it goes back in exatly the same position. You can see it has slots to allow rotation.
    If you are using a 500v Megger type insulation tester keep it well away from the same circuit board, only test at the windings (U, V, W), if it's just a multimeter that will not be a problem.
    On the main board there is a white connector with 2 white wires going to it, beside it is a 3 leg component mounted on a small vertical heatsink, well the legs on that do not look good, it looks in fact like someone has changed it before. Maybe this is a component that blows often ?
    There is a rectifier with GBU 12G written on it, this could also be causing the problem.
    http://www.datasheets.pl/bridge_rectifiers/GBU12A.pdf
  2. The Following User Says Thank You to EddyCurrent For This Useful Post:
  1. Can anyone identify this control board and help use it
    By SimonMaltby in forum Chinese Machines
    Last Post: 28-12-2017, 01:35 PM
  2. eBay: Emco vmc 100 milling machine and control unit plus manuals
    By Lee Roberts in forum Items On eBay UK
    Last Post: 15-06-2017, 05:16 PM
  3. Replies: 0
    Last Post: 06-02-2014, 09:52 PM
  4. eBay: Denford Novamill SmartStep Control Board + Spindle Board
    By danielbriggs in forum Items On eBay UK
    Last Post: 30-05-2013, 06:52 AM
  5. Help! Stepper control board
    By Ross77 in forum General Electronics
    Last Post: 28-05-2009, 01:42 AM
