  1. #10
    Quote Originally Posted by BILLYBOUM View Post
    Hi Eddy, many thanks for your helping documents and comments, and i'm impressed by your sharp eyes and knowledge !!!
    -1- Yes i ticked marks to position-back the rotary circuit on top of the motor, but yes i try to test everything on this circuit - including small Hall-effect tripods - is that deadly for them ( my multimeter is a FLUCKE, switched to BuzzerOhm-meter ) ?
    Using the Fluke meter is okay.
    -2- I suppose i have to de-solder the GBU12G to test it correct ?
    Yes
    -3- you are right as well for the 3 legs that look re-soldered : do i have to de-solder this component as well and how come is possible to test it ?
    ideally, can you see a number on this component ?
    -4- i have the "old" contol-board where i plugged by mistake ( at the wrong place ) the rpm information : may be it is easier to check and repair this board ? ( the present board is burning the 2 protective fuses almost instantaneously, the previous one just doesn't work and leaves the fuses OK by the way )
    You can use this to make a comparison with the other board, you can test the components without de-soldering them for a start then if you find a difference you can de-solder it to test it properly.
  2. The Following User Says Thank You to EddyCurrent For This Useful Post:
  1. Can anyone identify this control board and help use it
    By SimonMaltby in forum Chinese Machines
    Last Post: 28-12-2017, 01:35 PM
  2. eBay: Emco vmc 100 milling machine and control unit plus manuals
    By Lee Roberts in forum Items On eBay UK
    Last Post: 15-06-2017, 05:16 PM
  3. Replies: 0
    Last Post: 06-02-2014, 09:52 PM
  4. eBay: Denford Novamill SmartStep Control Board + Spindle Board
    By danielbriggs in forum Items On eBay UK
    Last Post: 30-05-2013, 06:52 AM
  5. Help! Stepper control board
    By Ross77 in forum General Electronics
    Last Post: 28-05-2009, 01:42 AM
