15-02-2014 #1
I'm sure this must of been asked before but I can't find it.
1/ To mill a pocket and leave the top outside edges without burs which direction should the spindle be traveling if the tool rotation is clockwise ? And when cutting an outside profile ??
2/ What is the quickest way in cambam to send the spindle around the top outside edge of a profile to do a quick clean up ?Last edited by dudz; 15-02-2014 at 07:01 PM.
Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
Axis Directions
By ptjw7uk in forum Linear & Rotary MotionReplies: 9Last Post: 18-02-2022, 08:45 AM -
RFQ: CLOSED - Aluminium milling and anodising
By AlexTsekenis in forum Projects, Jobs & RequestsReplies: 0Last Post: 12-05-2014, 10:11 PM -
Milling Sheet Aluminium
By p1lts in forum Metalwork DiscussionReplies: 8Last Post: 08-03-2014, 12:23 AM -
Best Tips for Cutting 6082 Aluminium (CNC Lathe)
By fidia in forum Metal Finishing TechniquesReplies: 0Last Post: 29-12-2013, 07:09 PM -
6082 Aluminium billet test
By dudz in forum Metal Finishing TechniquesReplies: 1Last Post: 22-09-2013, 10:45 AM
