04-01-2014 #7
Fatal to do that and you should always ask no matter how dumb you may feel because it's very easy to buy the wrong stuff and chances are someone will know a cheaper source.
Well all I can say is you have been looking in the wrong places. I'll say it again but said it many times on the forum, go to your local steel supplier and get a price. I can buy 7.5mtr lengths 50x50x3 for around £30 so a good steel supplier will be around the same.
Doesn't matter about the level of the machine so save your money. What matters most is that the surface the rails sit upon are on the same plane and parallel to each other.
Has for the frame being square then that's not so important again whats important is the Gantry is square to the rails it runs upon. To square the frame then just carefull measuring across the diagonals is enough.
Like I say search the forum and you'll see many examples of people showing how they set rails on the same plane and some of the tricks like adjustable top rail. Epoxy resin and Epoxy putty along with adjustable top rails make aliagning easy enough.
Steel frame with high sides and adjustable bed is the way to go if you want a decent all round machine.
Good luck.
I need advise again
By habibuzziwa in forum General DiscussionReplies: 14Last Post: 08-10-2012, 10:08 AM -
I need advise
By habibuzziwa in forum General DiscussionReplies: 7Last Post: 03-10-2012, 10:50 AM -
Confused need help!
By manofgresley in forum CAD & CAM SoftwareReplies: 12Last Post: 08-08-2012, 08:30 PM -
NEW MEMBER: New and confused!
By nicodemus in forum New Member IntroductionsReplies: 2Last Post: 10-07-2011, 12:12 AM -
Spindle help, please advise
By djh82uk in forum Spindles & Drive MotorsReplies: 2Last Post: 22-09-2007, 04:02 AM
