Thread: Tool Life Expectations?
Awesome - the material removal rate is fantastic compared to the raster/offset paths I'm using out of Vetric and there's something very "right" about chips and the way they come off of the cutter.
2000mm/min doesn't sound too aggressive (I assume that's the rough maximum as iMachining varies the feed) - I was expecting 3-4000mm/min max, but as you say its No. 2 out of 8+ settings.
05-01-2014 #2
Well it doesn't so much change the Feed but more it adjusts the stepover when you go to higher settings.
How it works is by varying between a Minimum and Max stepover and feed rate in differant areas to maintain a constant chip load and positive tool engagement.
To give an example of going one setting higher. 8mm Carbide 11mm flute length cut depth 15mm done in 2 passes [email protected] DOC 2nd @ 6.6224mm
#2 setting
Min Step over 0.160mm Max 1.050mm feed 2411mm/min Spindle speed 13,571Rpm x 2 steps . . . . Cut time per part 3.27mins
#3 setting
Min Step 0.560 Max 1.710 Feed 2498mm/min 14,667Rpm x 2 steps . . . . Cut time per part 2.10 mins!!
My machine would have handled this and possibly higher but didn't want to push it.!
Just for giggles.
#8 Min step 2.880mm Max 3.310 Feed 3902mm/min 16.213Rpm x 2 steps . . . . Cut time per part 0.52 Mins.!!!!
This would rattle my machine into pile of nut n bolts and melt down the spindle. . Lol
Funny enough Same but with flute length to allow full 15mm DOC so only 1 x pass isn't that much quicker due to lower STO & feeds.
#2 Cut time per part 3.08 min
#3 Cut time per part 1.54 min
#8 Cut time per part 0.42 Min
Edit: Oh by the way just checked code and that video was done on setting #1 not #2 and thats why feeds are lower at around 2mtr/min. Total time for 3 parts was around 15mins I seem to remember.?Last edited by JAZZCNC; 06-01-2014 at 05:28 PM.
A new life - irving reborn after near fatal accident
By irving2008 in forum General DiscussionReplies: 217Last Post: 25-01-2015, 02:50 PM -
The tough life that formed Yorkshiremen?
By WandrinAndy in forum General DiscussionReplies: 2Last Post: 26-05-2013, 10:01 AM -
What tool would you use for this?
By Kai in forum Tool & Tooling TechnologyReplies: 1Last Post: 21-03-2011, 06:08 PM -
A little conversion tool
By D-man in forum Computer SoftwareReplies: 1Last Post: 18-12-2010, 04:58 PM -
why is nothing in life simple!
By ptjw7uk in forum General DiscussionReplies: 7Last Post: 08-07-2009, 09:21 PM
