Thread: Chinese 3040T Arrives
	12-01-2014 #21
If it ain't broke don't fix it. Have some fun with the machine first. If you really want to change them I would use either 0.75 or 1mm^2 CY 4 core cable for this machine. here is one place Cy Cable Per Meter 4 core (0.75mm CY Cable) ONLY £0.48.. ..Clive
	12-01-2014 #22
	12-01-2014 #23
Most (including me use 4 wire CY shielded cable) on their machines - I think I got mine from RS Components, but that's likely the expensive route.....you'll need to make sure all your shielding is grounded to a single point to mains ground (a star point is the term iirc) and make sure the far end of the cables at the motors etc. is not contacting anything to avoid ground loops (these are bad). I used bits of heat shrink to ensure isolation for the far ends.
Hope that helps......
	12-01-2014 #24
Thanks for the advice,Think I will order cable and connectors so I have them but won't fit until there is a fault.
	12-01-2014 #25
In this instance what is the difference between 'good cables' and 'not very good cables' ? also will your proposed 'good cables' fit inside the energy chain ?
	12-01-2014 #26
Good point EddyCurrent. There is a local electrical wholesalers close who I am friendly with so I will check with him I hope he would be able to get 4 wire CY shielded cable the same size,
	12-01-2014 #27
My experience with these machines is that standard cy cable from like of CSE cables etc is far superior. The stuff on these is brittle horrible stuff and the connectors are nasty so need hacking off. . . . . The cable chains on the one's I've dealt with where to tight and caused rubbing. . .. . . That's why I said what I said further down.!!
	12-01-2014 #28
	18-01-2014 #29
Back from a couple off weeks work I had a play with the cnc and took the table off it just for a nosey
Hopefully I will get to put table back on and cut something tomorrow .
	18-01-2014 #30
I think it's looking quite good.
Chinese Spindles
By Ricardoco in forum Generic Chinese SpindlesReplies: 123Last Post: 05-12-2016, 12:16 AM -
BUILD LOG: From Chinese to Taffynese
By Carlb1058 in forum DIY Mill Build LogsReplies: 6Last Post: 09-07-2013, 12:03 AM -
WANTED: 2.2 KW Chinese Spindle
By Chaz in forum Items WantedReplies: 2Last Post: 17-06-2013, 10:03 AM -
Chinese spindles
By Colin Barron in forum Marketplace DiscussionReplies: 15Last Post: 23-08-2011, 08:58 PM -
Chinese 1.5kw Spindles
By jcb121 in forum Generic Chinese SpindlesReplies: 12Last Post: 28-07-2011, 06:20 PM
