Thread: Ross77's Z Axis Design
Design Link: Concept supported rail Z axis design
I think the difficulty with your idea lies with achieving sufficient accuracy on both axes, but particularly Z, to be able to mount the linear bearings. Normally people orientate the joints on Y such that at least one pair of bearings can be adjusted relative to the other, so assuming the rails are parallel that means the bearings will run smoothly. With your proposal, this could be done on Y or Z, but probably not both, which leaves the problem of machining the parts sufficiently accurately so that adjustment is not required. It's manageable if you have a suitable size milling machine, but probably impractical otherwise?Last edited by Lee Roberts; 08-01-2014 at 03:40 PM. Reason: Added quote and design link
	20-05-2013 #2
I see your point but I don,t think its a deal breaker, shims in the mounting pockets or grub screws pressing on a metal plate between the bearing (like a jib in a dovetail) would easily give the required adjustment.
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
Z-Axis design and advice
By Mad Professor in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 06-04-2013, 11:00 AM -
Help wanted design laser X-axis
By gavztheouch in forum Open Source Designs & PlansReplies: 12Last Post: 11-03-2013, 07:00 PM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM -
Y axis design
By GeorgeD in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 15-07-2010, 03:04 AM
