Page 2 of 2 FirstFirst 12
    Lives in Marple Stockport, United Kingdom. Last Activity: 21 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,347. Received thanks 620 times, giving thanks to others 89 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    The specs say that the MA860H will take both 80VAC and 110V DC, which is probably why it is more expensive.
    I'll check out AliExpress and add DQ860MA to my list of possibles.
    I don't touch mains projects and am quite happy to pay extra for a ready made SMPS.
    Here PS806-5 Linear power supply. If you don't want to build one. ..Clive
    Thanks Clive that's good to know. Hadn't consider the ready made linear route. I see it also gives 5v which would power the types of BoB which use terminals rather than USB power. All good info . . .
    £114 including VAT and shipping ... wow.
    So long as you don't need it within the next 2 weeks, I'll make you one for £65, but using a 600VA transformer not 500VA as 500VA is a bit on the small side for 4 motors. It wont look as pretty but it'll work.
    I'm not going to try and encourage you to start touching mains projects, as I don't know your reasons for not doing so. However, should you decide to then there's a good thread detailing what to do and if you want any advice it wont cost a penny....
    I don't need the electrics yet - not for a month or so. Need to finish the machine first.
    That's a kind offer thankyou - but am I missing something then with this sort of thing?:
    600W 60V 10A Switching Power Supply With Current Control Charger LED CCTV UKD | eBay
    I've read that the back EMF of the steppers means you need to overspec the current of the SMPS - is that where the above would limit the performance of the 80V driver setup over the linear 600VA type?
    As for mains there are just too many risks for me. Not only the first switch on, but later on with perhaps a poor earth or even a fire. I need something which has been built, tested and warranted so that I can get on with the bit I enjoy which is the Engineering and machining.
  5. #15
    This is what Leadshine say
    "Regulated or Unregulated Power Supply
    Both regulated and unregulated power supplies can be used to supply the drive. However,
    unregulated power supplies are preferred due to their ability to withstand current surge. If regulated
    power supplies (such as most switching supplies.) are indeed used, it is important to have large
    current output rating to avoid problems like current clamp, for example using 4A supply for 3A
    motor-drive operation. On the other hand, if unregulated supply is used, one may use a power supply
    of lower current rating than that of motor (typically 50%~70% of motor current). The reason is that
    the drive draws current from the power supply capacitor of the unregulated supply only during the
    ON duration of the PWM cycle, but not during the OFF duration. Therefore, the average current
    withdrawn from power supply is considerably less than motor current. For example, two 3A motors
    can be well supplied by one power supply of 4A rating. "
  6. #16
    I think this is a very sensible approach , in my opinion the unregulated power supply is best as it does not generate any noise type interference etc. ..Clive
  1. Replies: 1
  2. Stepper Driver requirements?
    By Dwayne Dibbley in forum Motor Drivers & Controllers
    Last Post: 24-07-2013, 05:29 PM
  3. best stepper driver???????
    By Ross77 in forum Motor Drivers & Controllers
    Last Post: 21-04-2013, 05:05 PM
  4. WANTED: stepper driver module
    By tinshak in forum Items Wanted
    Last Post: 16-01-2013, 09:31 AM
  5. Which stepper driver
    By Colin Barron in forum Motor Drivers & Controllers
    Last Post: 25-09-2010, 08:33 PM
