09-01-2014 #2
Yes some sort of angular velocity sensing is required for the spindle.
Unfortunately Mach3 apparently only works with 1 pulse per revolution sensors, which can work if the spindle inertia is high (i.e. big lathe), or the length of the thread is short. However LinuxCNC supports sensors with many pulses per revolution - it's limited more by the interface (parallel port generally), not the software.
The sensor needn't be anything complicated. Position an infra-red LED and detector either side of a disk with slot(s) in it attached to the spindle, and wire it up to one of the inputs on your controller.
Do you allow price check threads?
By dynamis_dk in forum Marketplace DiscussionReplies: 27Last Post: 16-04-2014, 10:07 PM -
RFQ: Dublin, IRL Manual milling & lathe work required
By 250rri in forum Projects, Jobs & RequestsReplies: 0Last Post: 30-01-2014, 01:07 PM -
RFQ: Lathe Work Required, Small Batches,
By Ptee in forum Projects, Jobs & RequestsReplies: 0Last Post: 17-01-2014, 06:13 PM -
where are the Mach3 discussion threads located ??
By John S in forum General DiscussionReplies: 6Last Post: 01-08-2012, 01:26 PM -
RFQ: Manual Lathe Repair & Syil SX3 CNC Re-build Required.
By Chas in forum Projects, Jobs & RequestsReplies: 0Last Post: 07-11-2010, 09:28 AM
