The plot thickens...
I'm going to use furniture bolts so I was planning to counter bore the holes. I imagined I would have to do that in another pass but it might be possible to do it in a single pass with a bit like this:
Wealden Tool Company Limited Drill Counterbore
If I can find one big enough (10mm pilot, 16mm counter bore, 25+mm cutting length)... is that likely? I would have to counter bore on each face anyway so that would remove the advantage of through drilling if I could drill and counter bore at the same time.
Ok PCB milled now how to drill the holes ?
By Fivetide in forum CAD & CAM SoftwareReplies: 13Last Post: 12-05-2013, 08:31 PM -
Drill 4 x 28mm holes through 44mm thick aluminium
By WandrinAndy in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 30-09-2012, 09:17 AM -
Now if only someone invented a drill that drilled square holes.....
By HankMcSpank in forum General DiscussionReplies: 3Last Post: 20-10-2011, 10:07 PM -
Drilling force monitering/chipped drill detection/1000's of holes in SS
By PatK in forum Tool & Tooling TechnologyReplies: 3Last Post: 27-09-2011, 11:57 PM
