12-01-2014 #19
Thru drill like you posted will work resonably ok but depending on material and grain structure you will still possibly get some breakout.
Milling Holes is too slow and isn't often done for holes this size and in wood. Much quicker to drill just past half way with No or few Peck's then flip material and use same G-code.
This is really the only way you can guarantee no tear and If you find the Drill/Counter bore you need then this will save loads of time.
Also there's nothing wrong with using a Hand drill for drilling, that's what it's designed to do, just don't try using it for Milling that's when you have trouble.!Last edited by JAZZCNC; 12-01-2014 at 11:44 AM.
Ok PCB milled now how to drill the holes ?
By Fivetide in forum CAD & CAM SoftwareReplies: 13Last Post: 12-05-2013, 08:31 PM -
Drill 4 x 28mm holes through 44mm thick aluminium
By WandrinAndy in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 30-09-2012, 09:17 AM -
Now if only someone invented a drill that drilled square holes.....
By HankMcSpank in forum General DiscussionReplies: 3Last Post: 20-10-2011, 10:07 PM -
Drilling force monitering/chipped drill detection/1000's of holes in SS
By PatK in forum Tool & Tooling TechnologyReplies: 3Last Post: 27-09-2011, 11:57 PM
