  1. #4
    Quote Originally Posted by andrew583 View Post
    I've been using that controller on a small 3040 CNC mill for the last couple of years, using MACH3.
    Ok well not getting into this debate again but will just pickup for the sake of others on the fact the board is NOT a controller. Mach3 is the controller and is software based. The board is simply combined drives and I/O interface nothing more.
    I do feel it would be a wise investment to get it early - otherwise if you buy the big kit in one fell swoop you'd have a mountain to climb to get everything working. With this box and just a single stepper and some microswitches you can learn the basics.
    Again in the interest of saving people money from buying Crap hardware.! . . . . There is no mountain to climb It's just the same with a couple more wires.? Then repeat for each axis.
    The process is easy enough You connect motor wires to terminals on a board just the same with the only difference being you have 2 extra pair of wires for Step and Direction. That's it other than providing power to each drive which you have to do only 1 time with this controller.
    The limits and Home or correctly termed I/O's are just the same no matter which setup.
    The Controller Mach3 needs the same setting up as the cheap controller does with absolutely no difference in the process, just with differant numbers for the I/O so it knows where to look.
    Don't get me wrong here I'm not getting at you just making it clear for those sat in the back ground(You know who you are) who don't ever speak up or ask but buy off reading post's like this.
    Yours is a fair assement based on your single experience which is good and applaude you for giving it. But I've experienced lots of this crap thru helping others and it's not worth the hassle considering much better drives can be had cheap. The " It's easy " reasoning or " It's cheap" is wrong way to view it because it's not cheap when it goes "Boom" which often happens and it's not easy when your pulling hair out trying to find out what happened with limited experience.!
    Like wise the individual drive setup isn't hard to setup or get your head around and if folks can't do this then maybe they should be questioning the whole idea of DIY CNC.??
  1. BUILD LOG: My Budget CNC Router
    By Nealieboyee in forum DIY Router Build Logs
    Last Post: 14-11-2012, 12:57 PM
  2. CONVERSION: X2 conversion on a budget!
    By craigrobbo in forum Conversion Build Logs
    Last Post: 30-10-2012, 05:00 PM
  3. Which spindle with a £200 budget?
    By fasteddy in forum Marketplace Discussion
    Last Post: 29-06-2010, 11:51 AM
  4. Some thoughts on budget workshops
    Last Post: 02-08-2009, 04:11 PM
  5. Laptop controller question.
    By m.marino in forum Laptops & Tablets
    Last Post: 07-01-2009, 04:33 PM
