18-01-2014 #5
I am expecting to replace the full gubbins, but have the spindle and other parts serviced. Allthough, if the servoes do work, it will be a bonus. If i have read the spindle paperwork correctly ( fast browse, will read through later ), it will go from 1500 - 20k+, so should be capable of doing some stone, engraving at least, idealy, be able to surface a gravestone and engrave it.
i was sort of hoping to do the full re-fit, for around 3 or 4k at the most. If the servos and drives need replacing, they dont have to be industrial grade as its not going to be the main machine or running more than a few hours a day, ( am building that ), i just thought its a very good large machine base to start with, as long as the rails arnt bent,
I suupose a good question for me to ask advise on is
what would you check if you was going to have a look at a large machine of this type., apart from screws and rails. Am not sure there is power were it is so i might have to take a Jenny down there or rent one, any advice welcome
There are currently 32 users browsing this thread. (0 members and 32 guests)
TinyG CNC Controller in the UK?
By Nimbus in forum Marketplace DiscussionReplies: 0Last Post: 14-06-2013, 06:03 PM -
Controller Box
By M250cnc in forum Motor Drivers & ControllersReplies: 1Last Post: 21-11-2010, 01:34 AM -
Akkon controller
By bigfoot08 in forum Electronic Project BuildingReplies: 1Last Post: 03-05-2010, 07:27 AM -
Lathe controller
By Davidh in forum Milling Machines, Builds & ConversionsReplies: 1Last Post: 25-12-2009, 12:45 AM -
Controller box from PC case
By Smiler in forum Electronic Project BuildingReplies: 15Last Post: 24-12-2008, 03:46 AM
