Thread: Spindle too heavy?
12-01-2014 #2
Whichever way you tilt the machine, you're just going to transfer a component of the gravitational force on the Z-axis to one or more axes. If either X or Y uses a ballscrew, then you could re-orientate the machine to place the force on that axis, however that could cause problems if the stiffness of the machine frame in general is low, which seems likely.
If an axis is placed 15 degrees to vertical, the gravitational force will only be cos(15°) times less (i.e. 3%) than if the axis was vertical. However I think by 'on it's side' you mean have Z 15° to horizontal and Y 15° from vertical? In which case you've just transferred almost 97% of the Z-axis weight to the Y-axis nut...
Yes, a bungee cord attached to the ceiling would be nice and easy - assuming the machine is fixed to the bench!
Whilst it does give an even force, the annoying thing with that approach is you're adding even more mass (about 5kg to cancel the new spindle) to the gantry [Edit: Not thinking.. this doesn't apply as you can attach the pulley to a stationary point, i.e. bench the machine is upon], so the X and Y axes are going to wear out even faster. You could start cascading pulleys to reduce the mass, but that introduces other problems...Last edited by Jonathan; 12-01-2014 at 08:38 PM.
12-01-2014 #3
Moving Heavy Machine
By bobhome in forum Machine DiscussionReplies: 10Last Post: 09-09-2021, 11:41 AM -
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
FOR SALE: Exel HD1013 heavy duty CNC router
By Deuce_Coupe in forum Items For SaleReplies: 0Last Post: 04-06-2014, 01:50 PM -
Heavy Duty Extension Spring
By Stevetechguy in forum Manufacturer NewsReplies: 0Last Post: 17-10-2012, 04:45 PM -
FOR SALE: Aliminium Profile, 970mm x4, 5.75m, heavy + extra's LOOK !
By Lee Roberts in forum Items For SaleReplies: 0Last Post: 14-07-2009, 01:41 AM
