Thread: Spindle too heavy?
Springs will change their 'pull' depending upon how far they are stretched whereas a counter weight over a pulley would be constant at any Z position. If the weight was dangled inside a tube, that would prevent it flapping about.
12-01-2014 #2
One of the snags with counter weights is their mass, OK when static but any accelerating movements increase the forces required to move the spindle which may be counter productive.
I use gas struts which are more or less constant force with low mass. Can be a bit tricky finding the correct one, but there are adjustable ones which you can use, you start out with too high a force and let fluid out to get what is required.
Moving Heavy Machine
By bobhome in forum Machine DiscussionReplies: 10Last Post: 09-09-2021, 11:41 AM -
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
FOR SALE: Exel HD1013 heavy duty CNC router
By Deuce_Coupe in forum Items For SaleReplies: 0Last Post: 04-06-2014, 01:50 PM -
Heavy Duty Extension Spring
By Stevetechguy in forum Manufacturer NewsReplies: 0Last Post: 17-10-2012, 04:45 PM -
FOR SALE: Aliminium Profile, 970mm x4, 5.75m, heavy + extra's LOOK !
By Lee Roberts in forum Items For SaleReplies: 0Last Post: 14-07-2009, 01:41 AM
