Thread: Rockcliff Router Build, MDF
05-08-2007 #17
Yea fair point about rockcliff! I’ve decided to buy already built drivers now anyway.
After chatting with you and looking at the other choices I decided that www.routoutcnc.com was the best choice for me, you can read about my new drivers below:
Microstepping Bipolar Stepper Motor Driver:
Routout 25 Way D Quick Connect:The RoutOut CNC stepper motor drive has many uses including for CNC retrofitting / robot control or driving you own CNC machine. It is simple to wire and operates with no external current setting resistors needed. The RoutOut CNC stepper motor driver is a single axis, pulse width modulated (PWM), Micro-stepping Bipolar driver with Full / Half / Quarter / Eighth stepping capabilities.
It is directly compatible with all of the major CNC software including but not limited to RoutOut CNC ,Turbo CNC, Mach 2, Mach1, KCam, Ability systems – LPT Indexer, etc., the list goes on.
Features:
• 2.5 A 30V Output Drive Capabilities.
• 3V to 5V logic inputs.
• Synchronous Rectification for low power / heat dissipation
• Internal UVLO and Thermal shutdown circuitry.
• Small PCB foot print only 66mm x 77mm
• Internal 5V logic driver onboard (no need for 5v Supply)
• Enable – Turns the motor off when not being driven.
For a wiring diagram for use with Routout CNC see the PDF File (Link Below).
I managed to get this lot for £86.49 Inc P&P, they do charge more on their web site (£130.00 Inc P&P) but if you go to their eBay shop you can pick these up for less. They have a fast email response and seem like a good choice with just 2-3 days for a delivery, you can find there eBay link by Clicking Here!The Routout CNC 25 Way D Breakout has many uses including for CNC retrofitting / robot control. It allows you to wire to the parallel port / LPT port using screw terminals, this makes wiring limit / sensing switches to you CNC machine a breeze.
Features:
• All connected printer I/O lines have screw terminal connector.
• Very easy to wire limit / control switches.
Routout CNC Quick Connect 25 Way D PDF
Cheers and thanks again.Last edited by Lee Roberts; 20-08-2010 at 12:44 AM.
RFQ: Does anyone want to build me a cnc router?
By totally useless in forum Projects, Jobs & RequestsReplies: 31Last Post: 08-05-2014, 09:55 PM -
By PilotTom in forum DIY Router Build LogsReplies: 12Last Post: 25-05-2013, 03:49 PM
