Brilliant, so doing away with THC, what do i need on the z axis?
does it just need a manual setting or is it best to have a stepper motor connected to mach3 so it can set piercing height then cutting height plus lift it clear to rapid.
my torch will strike at 0.5 to 1mm and cuts at 0 to 1.5mm or so, up to about 6mm thick, after that it must be dragged.
Speed is of little importance to me.Last edited by Davek0974; 16-01-2014 at 10:01 PM.
17-01-2014 #2
I am sure it is possible without HF arc starting but I have never stopped to figure it out.
If you are only 1mm above and fixed vertical, where do the sparks go during the pierce?
Is there some software that will add a sideways component?
BUILD LOG: 4' x 4' plasma table build in Canada
By 190-v8 in forum DIY Plasma Build LogsReplies: 2Last Post: 02-02-2014, 01:19 AM -
By 190-v8 in forum Plasma Table MachinesReplies: 0Last Post: 29-01-2014, 12:27 AM -
RFQ: RFQ: Plasma Table
By D-man in forum Projects, Jobs & RequestsReplies: 3Last Post: 04-07-2010, 11:08 PM -
3M x 2M Plasma table build
By MonoNeuron in forum DIY Plasma Build LogsReplies: 14Last Post: 01-09-2009, 11:11 AM -
Plasma table 2m x 1m
By Robin Hewitt in forum DIY Plasma Build LogsReplies: 9Last Post: 19-05-2009, 12:48 PM
