    As it would be only plasma machine, you could go light and simple on everything. Take a look at the ebay kits they sell and improvise. The Proma kit they sell at they web also. I pointed it to you as the second piece is the Z driver and will simplify things even further if you have not bought the drivers for the motors. Look at his simple Z axis.
    it not my machine, cause the part i want to show you is hidden inside, so i can not make photo of it but that's what i meant for clocking the gantry belts:
    that is good idea for simple Z DIY CNC Plasma cutter axis rail car for nema 23 stepper motors | eBay
    If i were at this point where you are, i would buy a 1 second hand wide type square rail with bearing block or two for around 100-200eur shipped to you from ebay for the gantry, as it will be far better than the other solutions. This wider type of rail will hold a very light z perfectly, move it fast and precisely and simplify a lot the build.
    something like this LAW21EL+710-2 Linear Bearing 1Rail 2Block NSK Used Wide type K1 lubricate seal | eBay
  2. The Following User Says Thank You to Boyan Silyavski For This Useful Post:
  1. BUILD LOG: 4' x 4' plasma table build in Canada
    By 190-v8 in forum DIY Plasma Build Logs
    Last Post: 02-02-2014, 01:19 AM
  2. 4' x 4' plasma table build in Canada
    By 190-v8 in forum Plasma Table Machines
    Last Post: 29-01-2014, 12:27 AM
  3. RFQ: RFQ: Plasma Table
    By D-man in forum Projects, Jobs & Requests
    Last Post: 04-07-2010, 11:08 PM
  4. 3M x 2M Plasma table build
    By MonoNeuron in forum DIY Plasma Build Logs
    Last Post: 01-09-2009, 11:11 AM
  5. Plasma table 2m x 1m
    By Robin Hewitt in forum DIY Plasma Build Logs
    Last Post: 19-05-2009, 12:48 PM
