Andy wouldn't worry about the 2mm gap it's just the frame thats out of square which doesn't mean a lot. More important that the x axis gantry is square to the Y axis rails and the y axis rails are parallel to each other.
The Y axis doesn't look to be binding too much but it does look and sound very dry so get some grease in the ballnut or at least bit of light lube oil on the screws.! . . . If the coupling was loose then it's 90% chance you've found your problem.
One thing I didn't like the sound of was the rattling when you grabbed the end of the ballscrew. Check if the ballscrew is floating back n forth by grabbing the end, there should be no movement.
If this is ok then I'd just grease and lube everything and put back together. If the ballscrews don't have a small flat on the end then file one on to give the grub screw a flat surface to grip on then Loctite the coupling grub screws.
20-01-2014 #2
I had a bit of an issue with getting tighter at one end. I loosened the stepper bolts and coupling screws and bearing block and found the tightest spot then jiggled all the above to try and get it into the best position to bind the least. Seems to have done the job. I also had a slightly less tight coupling screw - wonder if it's a symptom of binding?
13-02-2014 #3
richie - thanks mate for your reply. It could be something like that causing a slight bind but I was unable to replicate any real significant difference in 'feel' during pushing the axis' by hand.
Sooooo, what did I do next? Well after getting really fed up with it all. I decided to take the advice of you guys especially jazz and his recommendations and I went shopping...
I bought MX3660 - 3-Axis DSP Based Digital Stepper Drive Max 60 VDC / 6.0A
SPS487. 48V unregulated power supply
3x SY60STH86-3008B Nema 23 Stepper motors
I also bought the screened cable recommended in another thread and rewired all 3 motors back to the control box. I’ve earthed all cables at the box end and replaced all components. It all fits nicely in my blue box too.
After all of this I have fired her up and she is running perfectly. No more stalling, missed steps, or dodgy inconsistent cuts!!!
Just want to say thanks to all you guys and to Jazz for his kit recommendations. So much smoother, quieter and working well! Now I finally have a machine I am happy to work with at last.
cheers guys. :-)
Got a few questions to ask about my setup to perfect it. But will ask them later. just wanted to let you guys know how it turned out!
thanks andy
13-02-2014 #4
Great news and happy your sorted. .
Can't beat good electronics they make a world of differance and don't workout that much more expensive in the grand scheme of things when you consider you only spend the money wounce and they work perfectly so No spending weeks pulling hair.!!
13-02-2014 #5
lol ain't that the truth. Sat watching nervously while it did its first test cut after being rebuilt. Phew that was nerve wracking!
Glad I listened to the advice regards new electronics. The bigger motors and the electronics make a HUGE difference with the way its running now.Looking forward to actually making things rather than fixing them lol. Thanks for all the time you guys took for your advice.
andy
Workshop & Noise Help
By kemo_2002 in forum Workshop & EquipmentReplies: 7Last Post: 12-04-2014, 10:16 PM -
Dell monitor making a funny noise !
By Lee Roberts in forum MonitorsReplies: 1Last Post: 13-09-2013, 12:11 PM -
MDF CNC Router plans / parts for home build beginners
By HiltonSteve in forum Gantry/Router Machines & BuildingReplies: 81Last Post: 10-06-2012, 02:33 PM -
Homepage occasionally displays incorrectly.
By Jonathan in forum General DiscussionReplies: 1Last Post: 08-06-2012, 09:15 AM -
Motor noise
By M250cnc in forum General ElectronicsReplies: 4Last Post: 25-11-2010, 02:06 PM
