In LinuxCNC you can specify a tolerance on the G64 command, so the controller sacrifices constant speed to maintain the toolpath within the specified tolerance. e.g. put 'G64 P0.05' at the begining of the G-code and the path will not deviate by more than the P from the true value.
You've raised a mildly interesting point there, which I think is worth expanding to show why what you've observed occurs. The velocity of each axis cannot exceed the values in the motor tuning, however the speed of the machine (i.e. the feedrate) can, unless the machine is only moving in one axis. This occurs because when two axes are moving at given velocities, the resultant feedrate is the vector sum of these velocities. One way to visualise it is as a right angled triangle, where (for example) the velocities of X and Y are the sides adjacent to the right angle - the length of the hypotenuse will equal the feedrate.
Example 1:
Suppose you set your maximum velocity settings for X and Y both to 1000mm/min, home the machine (so it's at 0,0) then enter 'G0 X100 Y100'. Mach will move both X and Y as fast as it can (as it's a G0 move), so the feedrate you actually get is ., assuming the machine can accelerate to that feedrate within the specified distance.
The practical upshot of this is you can specify a feedrate higher than the velocity setting, and get that feedrate in some circumstances.
Example 2:
Same as example 1, except we enter 'G1 X100 Y200 F1100'.
The required speed is 1100mm/min, so the following must hold: ., where X and Y are the X and Y axis velocities.
The Y axis must travel twice as fast as X to go in the correct direction (as 200/100=2), so we have .
We also have the condition .,due to the motor tuning settings.
From (2), ., so substitute that into 1:
Whence,
(You can also solve this graphically quite easily - which may be more intuitive.)
So the X and Y velocities do not exceed 1000mm/min, yet the machine can in this example cut at 1100mm/min.
In reality, it's probably not a good idea to use this 'feedrate bonus' as it makes the feedrate a function of the direction in which the machine is travelling, so unless you're cutting a single straight line the feedrate you actually get will vary (continuously if an arc move).
The Following 2 Users Say Thank You to Jonathan For This Useful Post:
16-01-2014 #2
16-01-2014 #3
16-01-2014 #4
16-01-2014 #5
17-01-2014 #6
OMG lol What did I just walk back into?
I wanted to update you on my progress with getting this jumping/ noise issue out of the way. Well... I figured that you guys Jazz I think mentioned it first that I was expecting too much and the speeds were too high with the rapid and cutting settings.
Well, Lo and behold after trying lots of different tuning combinations. I discovered setting the speeds too low also made for some horrible sounds. But I came across a another post with some supplier recommended settings. That were indeed a lot slower than what I had been gave.
These settings were actually found to be the best for my 6040 machine. And they are
steps velocity accel' step dir
X 320 2000 200 10 5
Y 320 2000 200 10 5
Z 320 800 150 10 5
My old settings that made the occasional noise and stalled the motors were
X 320 3000 200 3 1
Y 320 3000 200 3 1
Z 320 800 200 3 1
It sounds loads better now and doesn't fly about making my table shake slightly with the speed of movement of the gantry.
I have re-cut a few test pieces and haven't had the horrible sound or any missed steps.... yet ;-) Never say never eh!
I just want to say a really big thanks to all you guys for all of your invaluable advice I really do appreciate it and would have been stuck without all your help. cheers guys
Andy :-)
Workshop & Noise Help
By kemo_2002 in forum Workshop & EquipmentReplies: 7Last Post: 12-04-2014, 10:16 PM -
Dell monitor making a funny noise !
By Lee Roberts in forum MonitorsReplies: 1Last Post: 13-09-2013, 12:11 PM -
MDF CNC Router plans / parts for home build beginners
By HiltonSteve in forum Gantry/Router Machines & BuildingReplies: 81Last Post: 10-06-2012, 02:33 PM -
Homepage occasionally displays incorrectly.
By Jonathan in forum General DiscussionReplies: 1Last Post: 08-06-2012, 09:15 AM -
Motor noise
By M250cnc in forum General ElectronicsReplies: 4Last Post: 25-11-2010, 02:06 PM
