20-01-2014 #35
I had a bit of an issue with getting tighter at one end. I loosened the stepper bolts and coupling screws and bearing block and found the tightest spot then jiggled all the above to try and get it into the best position to bind the least. Seems to have done the job. I also had a slightly less tight coupling screw - wonder if it's a symptom of binding?
Workshop & Noise Help
By kemo_2002 in forum Workshop & EquipmentReplies: 7Last Post: 12-04-2014, 10:16 PM -
Dell monitor making a funny noise !
By Lee Roberts in forum MonitorsReplies: 1Last Post: 13-09-2013, 12:11 PM -
MDF CNC Router plans / parts for home build beginners
By HiltonSteve in forum Gantry/Router Machines & BuildingReplies: 81Last Post: 10-06-2012, 02:33 PM -
Homepage occasionally displays incorrectly.
By Jonathan in forum General DiscussionReplies: 1Last Post: 08-06-2012, 09:15 AM -
Motor noise
By M250cnc in forum General ElectronicsReplies: 4Last Post: 25-11-2010, 02:06 PM
