Thread: -10V to 10v circuit
13-01-2014 #3
Mach outputs a PWM signal to control spindle speed, so that's 0-5V (assuming 5V parallel port). You therefore need a circuit to convert 0-5V to -10 to 10v. You can use op-amps to subtract 2.5V from the signal (so it's -2.5 to 2.5v), and apply gain of 4 to get the correct range. Use an RC filter to get an analogue voltage level from the PWM signal.
Something like this circuit:
Non-Inverting Op-Amp Level Shifter
The op-amp would need a +-10V supply... one easy way, though probably not the cheapest way to get that is with one of these DC-DC converters.
Or you could get a breakout board which does it for you.
If you're using LinuxCNC then you could control the spindle speed using any of the position control (step/dir, cw/ccw etc) inputs, which is probably easier as it saves making the above circuit.
AM882 Alarm Circuit
By Wobblycogs in forum General ElectronicsReplies: 8Last Post: 28-03-2014, 06:06 PM -
E-STOP Circuit - will this cause any problems?
By birchy in forum General ElectronicsReplies: 34Last Post: 18-12-2012, 04:35 AM -
Printed Circuit Boards manufacturer
By stirling in forum General ElectronicsReplies: 9Last Post: 06-06-2012, 06:53 PM -
DC motor drive circuit?
By Tenson in forum General ElectronicsReplies: 4Last Post: 02-02-2012, 10:32 PM -
Milling Printed Circuit Boards - How To
By Lee Roberts in forum Electronic Project BuildingReplies: 0Last Post: 28-08-2008, 11:25 PM
