    Within Mach3 the user would use S for speed and M3,M4 for direction.
    In additiaon a Mach3 Brain could be used to read the Spindle Speed DRO and only operate the direction relay outputs if the speed was above a particular figure, this would give a deadband around the zero position.
    Then how do you start the Spindle or control it's speed thru G-code.?. . . . There will be better ways but I'm not wasting brain cells thinking about it because the guy has Servo drives that take Step/Dir so why make life hard.?
    Don't be silly now, you know how to do that. Also this thread is going off the rails due to lack of info from the OP, he's either controlling a servo driver or a VFD. The VFD is straight forward, use a spindle board from Mach3, the servo driver, who knows until more info is given ?
    Anyway I'm only looking at novel ways to derive a -10v to +10v output but nobody wants to play about with it or forward their own ideas.
    It's one of those days when I'm thinking, why bother ?
  1. AM882 Alarm Circuit
    By Wobblycogs in forum General Electronics
    Last Post: 28-03-2014, 06:06 PM
  2. E-STOP Circuit - will this cause any problems?
    By birchy in forum General Electronics
    Last Post: 18-12-2012, 04:35 AM
  3. Printed Circuit Boards manufacturer
    By stirling in forum General Electronics
    Last Post: 06-06-2012, 06:53 PM
  4. DC motor drive circuit?
    By Tenson in forum General Electronics
    Last Post: 02-02-2012, 10:32 PM
  5. Milling Printed Circuit Boards - How To
    By Lee Roberts in forum Electronic Project Building
    Last Post: 28-08-2008, 11:25 PM
