    Hi, i have got a WATER-COOLED SPINDLE MOTOR 2.2KW INVERTER VFD 2.2KW VARIABLE FREQUENCY DRIVE q4 from China from ebay. both the cable that connects the motor to the spindle and the hydraulic pump are missing and the supplier said that it does not come with them. How would you operate the spindle without these items? The supplier does not seem to give me an answer. If I do need these items, do you know where i could get them? Any help would be extremely appreciated . Many Thanks
    its how they all come,you should have a connector that screws onto the top of your spindle but you will have to get your own cable and water hose.
    there are posts on here regarding wiring and set up somewhere.
    many thanks Deisel :)
    Lives in Marple Stockport, United Kingdom. Last Activity: 15 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,345. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by deisel View Post
    http://www.mycncuk.com/threads/5814-...ce-More/page12 #6 gives some help with the setup ..Clive
    what would be the best water pump for this machine? I have seen that some users use quite powerful ones and others use quite small ones...which attachments does the pump need to have? does anyone have some links to show me examples? many thanks
    im just using a cheap £15-£20 pond pump submerged in the water tank.get the correct clear water hose that fits the two unions on top of the spindle that came with it, run these two to your water tank.
    only one of the hose will fit to the pond pump the other just drops into you tank as a return.
    what ever pump you get you just need to source or make 1 reducer that steps down from the pumps connecter to the diameter of the spindle hose.
  7. The Following User Says Thank You to dazza For This Useful Post:
  8. #7
    thank you very much
  9. #8
    Something like this will do http://www.ebay.co.uk/itm/1pc-Brand-...item233b53c288 put inside a Tupperware 2 ltr container. ..Clive
  10. The Following User Says Thank You to Clive S For This Useful Post:
  11. #9
    thank you so much
  2. Chinese 6040 from uk eBay seller x axis problem
    By CommanderKenyon in forum Gantry/Router Machines & Building
    Last Post: 20-02-2015, 02:13 AM
  3. Chinese Nema 34 packages on ebay
    By adamh in forum Marketplace Discussion
    Last Post: 06-12-2013, 12:24 PM
  4. Replies: 112
    Last Post: 07-10-2013, 03:38 PM
  5. WANTED: Spindle holder for 1.5kw Chinese spindle.
    By jcb121 in forum Items Wanted
    Last Post: 14-10-2011, 02:07 PM
