Thread: Stone Machine
29-01-2014 #14
Hi
spindles have efficiency curves, a lot of the 2.2 - 3 kw ones are tuned to perform between 18000 and 22000 rpm, below that speed, they don't have enough torque,a decent 3KW spindle will cut through anything as long as the feed rate is correct Gooing to 4.5 KW or higher doesn't make much difference these are usually to drive Long bits or large blades
a lot of the stone bits are low rpm, and some of the spindle i have looked at are High kw but have the torque at lower rpms, its one of the reasons i was considering a belt driven spindle, or a servo as a spindle, i still haven't made my mind up yet.Diamond has a finite working speed if too high it burnishes the Bits exactly the same as Using Carbide bits on granite and polishes the diamond flat.
LIMAC knife cutting machine and plasma machine, cnc router latest video
By therouterlady in forum Manufacturer NewsReplies: 0Last Post: 18-09-2013, 05:28 AM -
stone effect plastic sheet.
By don_jarr in forum Marketplace DiscussionReplies: 2Last Post: 20-03-2012, 11:43 PM
