No remember it's a simple a formula to find the Steps per. Divide the Micro steps by the Pitch. . . .So 800/5=160
This is an absolute calculation to within fractions of the calculated figure so when doing the Axis calibration it should be very very close if not the same has the calculated figure. If it's different by a lot then something is wrong.
Things that can cause this differance are the drives micro stepping not being set to what they say they are.?? . . Doesn't happen often but it does happen. (Or you are setting them wrong.!. . It's Common to mix up ON / OFF on Dip switches.?? )
Regards Velocity and Accelleration then you'll just have to play about has every machine is different. 5000 and 800 for X & Y shouldn't be too taxing if you have decent amount of volts on the motors. Slightly less on the Z axis.Last edited by JAZZCNC; 21-01-2014 at 12:14 AM.
22-01-2014 #2
Hi Jazz
You were absolutely right, something was wrong. As luck would have it I forgot my disk with the documentation regarding MS driver settings chart. I had to resort to removing a driver from my control box to look at the chart on there. Lo and behold, it seems I have the wrong docs for my drivers. The dip switch settings I have been putting in, eg, 1600 steps has been actually 3200, hence when I calibrated in Mach I was getting a figure of around 640 'steps per'.
I have now set the MS drivers to 1600, manually typed in the 'steps per' box 320. I played around with the velocity and acceleration settings and have ended up at 3000 and 800 respectfully on all three axes.
Everything seems to be running better now.
I don't know how long I would have gone on before making the discovery, good fortune has intervened by me forgetting the document disk, but it has been your insistence that something was wrong that has pushed me on to check and re-check settings.
Thank you again Jazz for your patience and knowledge for a greenhorn.
Jim
22-01-2014 #3
No problem just pleased you found it and sorry if I was blunt.!!
If your happy with those speeds then great and the 1600MS should give you nice smooth running motors but if you do want a little more speed then try at 800 and you should push it up around the 5000mm/min or higher.
What voltage are you running the drives on.?
22-01-2014 #4
Hi Jazz
The drivers are running on 36v, but I have the dip switch set to half power. When I was testing the motors they seemed to get quite hot at standstill with the holding torque when the drivers were on full power. I haven't changed them back.
One other question regarding settings in Mach, in the motor tuning the settings for step pulse and direction pulse (1 to 5) I have set to 2 in both boxes from my documentation. A tutorial video on you tube suggested that these are normally set to 0, any suggestions/recommendations?
Jim
23-01-2014 #5
23-01-2014 #6
Thanks Jazz, I will leave them set as they are as things are running OK.
Thanks again for all your help and advice.
Jim
bit of advice needed for first mill
By jmac80 in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 06-04-2014, 10:59 PM -
Advice please! JAF Motion Controller issues!
By Mark Chard in forum Machine Control SoftwareReplies: 0Last Post: 31-01-2014, 05:03 PM -
Quick Advice Needed - F&S
By Tenson in forum Tool & Tooling TechnologyReplies: 1Last Post: 01-01-2013, 06:38 PM -
Advice needed for Z Design
By Hobgoblin in forum Linear & Rotary MotionReplies: 8Last Post: 10-09-2012, 09:18 PM -
SPG X3 CNC Mill, advice needed please
By shaggyhawkings in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 07-01-2010, 11:00 PM
