Thread: Please help me... It wont work.
21-01-2014 #6
thankyou all for your input.
Jonathon: probing the end of the parallel cable with my voltmeter gives almost exactly the figures you have quoted. I also note (little more primative) if I poke an LED with resistor into the pulse pin, the led comes on while the arrow(jog) key is down (probably pulsing but too quick for my eyes) then goes off when you release the key. The direction pin likewise behaves as expected (LED on in one direction, off in the other)
However, if I repeat the above excercise at the output from the breakout board, the direction pin behaves the same. However the pulse pin just stays on regardless of if they key is down.
Ive tried (I know this isnt clever) wiring direct from the parrelel cable to the driver. but no action. (I assume the current is too low at the end of the parrelel cable?)
However, I wrote a simple program for the arduino to generate a pulse... wired that into the driver and the stepper turns as you would expect.
I spent last night playing round with the Charge Pump, and 'enabled' option on the bob. Still no joy.
Im now thinking, Id better try another break-out-board... but am open to advice on what to use. I have had a lot of success with the cheap BOB's that come from china 'free' with the DQ542MA drivers. However im not likely to get one of those on next day delivery so im scratching around at options.
Ive just ordered a 'available' ZP5A-INT' off zap, however got a follow up email saying its out of stock. So, Im after options that are going to facilitate next day delivery.... anyone?
RFQ: I am looking for work as cnc operator.
By krystiankania in forum Projects, Jobs & RequestsReplies: 0Last Post: 13-02-2014, 03:48 PM -
Poorly siemens inverter, wont switch on.
By jonisonvespa in forum Spindles & Drive MotorsReplies: 7Last Post: 06-12-2012, 04:45 PM -
Work in Norway
By Protech HR in forum Opportunities Available & SoughtReplies: 0Last Post: 11-09-2012, 10:12 AM -
WANTED: Frame work
By D-man in forum Items WantedReplies: 3Last Post: 30-12-2011, 09:03 PM -
NEW MEMBER: Back to work!
By Edge in forum New Member IntroductionsReplies: 4Last Post: 19-08-2010, 11:57 PM
