21-01-2014 #5
Yes I agree.!!. . . . .It will take it to Another level of head ache.!
Normal steppers don't even come close to these even with good drives and servo's offer nothing more other than speed and torque unless used with control that can close the loop correctly, infact they offer less if the loop isn't closed because they can only fault if a following error occurs not correct for positional loss.
If these drives/motors are sized correctly for the machine then they match servos for accurecy and absolutley blow them away for ease of use. No messing around with scopes and PID settings etc, just plug-in setup a few simple parameters and forget.
Servo's are great but they can also be a complete night mare and for DIY machine they can be more trouble than there worth with very little gain worth the trouble or cost.!!
Controller for 8NM closed loop leadshine drivers
By Matt81 in forum Motor Drivers & ControllersReplies: 5Last Post: 19-06-2014, 09:08 AM -
Testing Leadshine closed loop stepper system.
By JAZZCNC in forum Stepper & Servo MotorsReplies: 10Last Post: 13-10-2012, 05:39 PM -
Closed Loop Stepper Compared with Open Loop Stepper
By Leadshine-Erci in forum Stepper & Servo MotorsReplies: 0Last Post: 25-05-2012, 08:11 AM -
Closed Loop steppers
By funkmonkey in forum Stepper & Servo MotorsReplies: 24Last Post: 18-07-2009, 09:56 PM -
Droping Steps, closed loop ? HELP !!!
By bobin in forum Machine DiscussionReplies: 7Last Post: 20-05-2009, 03:56 PM
