A Vector drive will give full torque at zero speed, but with an asynchronous motor not a servo or stepper.
Have a read, look at the vector drive section.
http://www05.abb.com/global/scot/sco...14482_RevG.pdfLast edited by EddyCurrent; 24-01-2014 at 02:28 PM.
The Following User Says Thank You to EddyCurrent For This Useful Post:
24-01-2014 #2
Using vector control (also known as, FOC - field oriented control) also gets rated torque to zero speed with synchronous motors. Servo motors are generally permanent magnet synchronous motors and they will use FOC and hence can output rated torque down to zero speed, so long as the motor cooling is sufficient.
Stepper motors are less well defined in their ratings - with FOC they will output some value of torque between zero speed and some value, however this torque value isn't generally quoted in the datasheet, so it is unwise to make a general statement except that this value will be lower than the holding torque.
The Following User Says Thank You to Jonathan For This Useful Post:
Controller for 8NM closed loop leadshine drivers
By Matt81 in forum Motor Drivers & ControllersReplies: 5Last Post: 19-06-2014, 09:08 AM -
Testing Leadshine closed loop stepper system.
By JAZZCNC in forum Stepper & Servo MotorsReplies: 10Last Post: 13-10-2012, 05:39 PM -
Closed Loop Stepper Compared with Open Loop Stepper
By Leadshine-Erci in forum Stepper & Servo MotorsReplies: 0Last Post: 25-05-2012, 08:11 AM -
Closed Loop steppers
By funkmonkey in forum Stepper & Servo MotorsReplies: 24Last Post: 18-07-2009, 09:56 PM -
Droping Steps, closed loop ? HELP !!!
By bobin in forum Machine DiscussionReplies: 7Last Post: 20-05-2009, 03:56 PM
