    Hi, I'm after 100mmx100mm 6mm aluminium plate/sheet, but I need a good grade for machining which I cant find on ebay. I may need 2. If you have any let me know! :)
    Please see our online shop,:
    Aluminium small plate 6mm thick
    As well as running KB Aluminium, I am also UK marketing manager for Motedis. If you need anything else or have any questions please PM me.
    Regards,
    Kris
    I have some im getting rid of, all offcuts and new material if you still need any. Its 6062 plate and the most common machining grade. Please feel free to pm me.
    Kind regards
    Wal's Avatar
    Hi Kris,
    I'm also in the market for some alu plate - I had a quick look at your site and you certainly have the sizes I'm after, but the plate is listed as DIN EN AW-5083 - which, if I understand correctly, is a poor grade for machining..? Do you stock 6082 in the smaller sizes?
    Quote Originally Posted by KB Aluminium View Post
    Regards,
    Kris
    Wal 5083 Machines fine those that have trouble machining it are cutting it wrong.!
    Wal's Avatar
    Fair enough Jazz, I was just going off the Aalco datasheets:
    Aluminium Alloy - Commercial Alloy - 5083 - 0~H111
    ...but will trust your expertise and experience and give it a whirl - any hot tips? (No end-mill pun intended).
    Wal.
    Wal For your information there is a company in Hazel Grove, Stockport. Aluminium rolled plate & sheet | Metal Web | UK metals stockholder and processor.
    This is where I bought by ali from I ordered it and collected a couple of days later. At the time the price was about the same as AW Like all these places they have offcuts that you can buy without the cutting charge if you ask.
    Wal.
    Wal While 6 series does machine better I've never had any trouble machining 5083 series but some grades do machine better than others. The 5083 '0' plate Ali warehouse sells which is a lower grade machines fine. The H22/4 types are better.
    I know Metalweb keep H22 because several months ago I machined Gantry sides, Z axis etc for someone and it came from them. To be honest couldn't tell much differance to 6082.!!
    Avoid 5005 '0' if possible because that can be a little gummy and hard work.
    Nothing special to machining it just plenty of air/coolant and use good cutters. Can't really advise on cutting settings has I tend to use Rippers for roughing and straight flute for Finishing so unless you work similair then won't be much use to you. Also each machine as there own sweet spots so you'll need to play to find what suits your machine best.?
    Hi Kris,
    I will try to find out if we can get the 6082 for you. I am still finding my feet at Motedis and getting familiar with the shop system. I will PM you if I get any news for you.
    Regards,
    Kris
    Wal's Avatar
    Thanks Kris,
    Can't say fairer than that! Much obliged.
    Wal.
  1. eBay: 8x4 sheet of 25mm thick aluminium plate.
    By T0rnado69 in forum Items On eBay UK
    Last Post: 18-04-2014, 02:01 AM
  2. RFQ: Rounded slot milled through 15mm Aluminium plate
    By TonyD in forum Projects, Jobs & Requests
    Last Post: 15-02-2013, 11:20 AM
  3. what is aluminium plate
    By martin54 in forum General Discussion
    Last Post: 11-10-2012, 01:44 AM
  4. RFQ: 20mm Aluminium Plate Milling Request
    By Tenson in forum Projects, Jobs & Requests
    Last Post: 01-06-2012, 11:56 AM
  5. NEW Aluminium Ware house Now do Ali Plate + New Web page
    By JAZZCNC in forum Marketplace Discussion
    Last Post: 27-01-2012, 12:03 AM
