    Fair enough Jazz, I was just going off the Aalco datasheets:
    Aluminium Alloy - Commercial Alloy - 5083 - 0~H111
    ...but will trust your expertise and experience and give it a whirl - any hot tips? (No end-mill pun intended).
    Wal.
    Wal While 6 series does machine better I've never had any trouble machining 5083 series but some grades do machine better than others. The 5083 '0' plate Ali warehouse sells which is a lower grade machines fine. The H22/4 types are better.
    I know Metalweb keep H22 because several months ago I machined Gantry sides, Z axis etc for someone and it came from them. To be honest couldn't tell much differance to 6082.!!
    Avoid 5005 '0' if possible because that can be a little gummy and hard work.
    Nothing special to machining it just plenty of air/coolant and use good cutters. Can't really advise on cutting settings has I tend to use Rippers for roughing and straight flute for Finishing so unless you work similair then won't be much use to you. Also each machine as there own sweet spots so you'll need to play to find what suits your machine best.?
  1. eBay: 8x4 sheet of 25mm thick aluminium plate.
    By T0rnado69 in forum Items On eBay UK
    Last Post: 18-04-2014, 02:01 AM
  2. RFQ: Rounded slot milled through 15mm Aluminium plate
    By TonyD in forum Projects, Jobs & Requests
    Last Post: 15-02-2013, 11:20 AM
  3. what is aluminium plate
    By martin54 in forum General Discussion
    Last Post: 11-10-2012, 01:44 AM
  4. RFQ: 20mm Aluminium Plate Milling Request
    By Tenson in forum Projects, Jobs & Requests
    Last Post: 01-06-2012, 11:56 AM
  5. NEW Aluminium Ware house Now do Ali Plate + New Web page
    By JAZZCNC in forum Marketplace Discussion
    Last Post: 27-01-2012, 12:03 AM
